System Builder - Core i7-6700 3.4GHz Quad-Core, GeForce GTX 1060 3GB 3GB GAMING, Zondda-B ATX Mid Tower - PCPartPicker
Hi. This is long so please bear with me, I really appreciate your help.
For 6 months now I have my pc which is about a year old driving me mad. A few problems, not sure if they are related:
1. Sometimes the computer microfreezes, accompanied by a buzzing sound. This is replicable 95% ofthe time by loading a new netflix or amazon prime video (but not twitch or youtube), as the video loads. (Videos included). It also happens rarely if I watch my friends on steam playing games with steam broadcasting
-NOTE: This issue doesn't seem to occur in safe mode. It seems to happen when I install nvidia drivers, but I tried different driver versions and I haven't found anyone else with the issue. I have tried replacing my GPU.
Recorded internal audio with OBS:
YouTube
Recorded with phone:
YouTube
2. Lagging and frame skipping in onlinevideos, on any online video platform (twitch netflix youtube etc.) Iget micro frame freezes and lag, sometimes videos will play at like20 fps for 1 or 2 seconds at intervals (not buffering/loadingrelated, my internet is pretty stellar).
3. I get audio static/crackling veryrandomly, seemingly mostly from online videos. This happens both fromaudio speakers plugged in the rear and earphones plugged in front.
Not sure you can tell from the videos,but as I load a new spongebob episode from amazon prime, the audiocuts out for a sec. It ALSO creates a buzzing sound, which theinternal audio didn't record for some reason, but it's the exact typeof sound like form this:
YouTube
I have tried: Reinstalling audio drivernumerous times, from motherboard manufacturers website, from Realtek, different version, etc. Tried different GPU drivers. None helped.
I'm getting to the point where I thinkI have to RMA my motherboard, which really sucks. I wanted to ask you guys since you are a smart knowledgable group, if there are any othertests or anything to try before trying to replace my motherboard.
[FONT="]I ran latencymon, it seems to have found a problem?[/FONT]
[FONT="]It says [/FONT]
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates. LatencyMon has been analyzing your system for 0:03:05 (h:mm:ss) on all processors.
([FONT="]This forum really needs spoiler tags)[/FONT]
Imgur: The magic of the Internet
[FONT="]Lots of other text from latencymon Stats, I can post it if needed. It seems dxgkernl.sys and ndis.sys are giving problems[/FONT]
Highest ISR routine execution time (µs): 223.396714 Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.235274 Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
I ran latencymon a second time today, got much more normal results, and latencymon indicated I was having no problems. Do you think it's a latency problem?
Thanks!
