Page 2 of 2 First 12
  1. #21
    Re: Driver Power State Failure due ACPI.sys
    It still showed the Driver power state failure. I might need to update the bios. Can any of you help me a bit with that?
    I don't know if there is currently a newer version for my bios. It runs on American Megatrend Inc. v.5.11, bios says Aptio (but not if that is V or 4).
    On the boot menu, there is UEFI.
    • Ad Bot
      advertising
      Beep.
  2. #22
    xilolee's Avatar
    Join Date
    Dec 2013
    World, Europe, Italy
    • specs System Specs
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
        Windows 10 Home/Standard x64
    Does a support webpage for our product exist on the manufacturer website?
    I searched it yesterday, but I didn't find it.
    Hence, if you have got a certain and direct link to it, it's better.
  3. #23
    Well, I have not found it either, only the official website of Cube (Link: i7手写本 | 酷比魔方官网 which is fully in Chinese, without any downloads).
    I did get my hands on official bios firmware, but that version was older than the one currently installed.
    Actually, I think there is no new version of the bios (yet). Is there a way reinstalling the current bios could fix problems?
    Or perhaps, is there any other solution left to stop the BSOD from occurring in Windows 10? (maybe an older version of Windows?)
    It seems Ubuntu runs perfectly fine on the system.. so could it really be hardware what is causing the problem?
  4. #24
    It's really frustrating. I've been working on a repair for this tablet for 3 weeks straight and still, the Driver Power State Failure occurs.
    I just set the BIOS back to default settings and tried a new installation of Windows 10, but even right after the installation finished and the tablet rebooted the BSOD came up.
    Good thing Ubuntu does run fine on the tablet, which is a bit strange though. I really want to run Windows on it, as I am used to that for years now.
    Could it really be a hardware issue? If so, how can I find out what is causing the problem? and could I possibly fix it?
    I was also thinking it could have something to do with power supply (or management) because the tablet won't charge with the 3,5mm wall charger (it does charge fine with the USB-C wall charger though)
Similar Threads
  1. [SOLVED] Driver Power State Failure BSOD
    By RainChaos in forum BSOD, Crashes, Kernel Debugging
    Last Post: 05-22-2017, 11:49 AM
  2. Driver Power State Failure - Windows 8.1 x64
    By RichardVN in forum BSOD, Crashes, Kernel Debugging
    Last Post: 12-01-2014, 09:23 AM
  3. [SOLVED] BSOD - DRIVER POWER STATE FAILURE (ACPI.sys)
    By Fardarkside in forum BSOD, Crashes, Kernel Debugging
    Last Post: 09-28-2013, 05:54 PM
  4. [SOLVED] BSOD - DRIVER POWER STATE FAILURE
    By maharlikans in forum BSOD, Crashes, Kernel Debugging
    Last Post: 01-06-2013, 05:26 AM
Log in
Log in
