1. #1
    bsod error 116 help pls
    Please help am getting bsod error 116 each time i tried upgrading drivers reinstalling everything same issue
    Attached Files Attached Files
    • Ad Bot
      advertising
      Beep.
  2. #2
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
    • specs System Specs
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
        12GB DDR3L SDRAM (2 DIMM)
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    Re: bsod error 116 help pls
    Hi -
    All 21 dumps had bugcheck 0x116 - video TDR timeout.
    Try and update the drivers - Driver Reference Table (DRT)
    If no-go, roll the drivers back.
    If still no-go, you'll need to swap out the video card as there may be a problem with it.
    Regards. . .
    jcgriff2
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122417-22994-01.dmp]
    Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
    Debug session time: Sun Dec 24 08:47:06.569 2017 (UTC - 5:00)
    System Uptime: 0 days 6:54:33.927
    *** WARNING: Unable to verify timestamp for atikmpag.sys
    *** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
    Probably caused by : atikmpag.sys ( atikmpag+f948 )
    DEFAULT_BUCKET_ID:  GRAPHICS_DRIVER_TDR_FAULT
    BUGCHECK_STR:  0x116
    PROCESS_NAME:  System
    FAILURE_BUCKET_ID:  X64_0x116_IMAGE_atikmpag.sys
    Bugcheck code 00000116
    Arguments fffffa80`08fcc010 fffff880`04a16948 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    BiosReleaseDate = 05/19/2015
    SystemManufacturer = MSI
    SystemProductName = MS-7845
    MaxSpeed:     3200
    CurrentSpeed: 3200
    ииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииии``
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122517-19156-01.dmp]
    Debug session time: Mon Dec 25 04:42:35.869 2017 (UTC - 5:00)
    System Uptime: 0 days 2:42:38.289
    BUGCHECK_STR:  0x116
    Arguments fffffa80`07db4010 fffff880`04af2948 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122517-25365-01.dmp]
    Debug session time: Sun Dec 24 18:27:02.055 2017 (UTC - 5:00)
    System Uptime: 0 days 0:04:37.047
    BUGCHECK_STR:  0x116
    Arguments fffffa80`07fc9010 fffff880`046d0948 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122517-25755-01.dmp]
    Debug session time: Sun Dec 24 18:22:01.910 2017 (UTC - 5:00)
    System Uptime: 0 days 9:34:31.331
    BUGCHECK_STR:  0x116
    Arguments fffffa80`0912a010 fffff880`04b04948 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122517-26332-01.dmp]
    Debug session time: Sun Dec 24 18:40:44.890 2017 (UTC - 5:00)
    System Uptime: 0 days 0:09:30.310
    BUGCHECK_STR:  0x116
    Arguments fffffa80`0727e010 fffff880`04762948 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122517-26629-01.dmp]
    Debug session time: Mon Dec 25 01:48:51.823 2017 (UTC - 5:00)
    System Uptime: 0 days 0:04:30.869
    BUGCHECK_STR:  0x116
    Arguments fffffa80`0387e010 fffff880`0420f948 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122517-27409-01.dmp]
    Debug session time: Mon Dec 25 05:40:29.008 2017 (UTC - 5:00)
    System Uptime: 0 days 0:56:14.428
    BUGCHECK_STR:  0x116
    Arguments fffffa80`03da84e0 fffff880`04aa4948 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122517-28126-01.dmp]
    Debug session time: Mon Dec 25 01:32:00.451 2017 (UTC - 5:00)
    System Uptime: 0 days 0:47:24.497
    BUGCHECK_STR:  0x116
    Arguments fffffa80`0847c4e0 fffff880`0484a948 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122617-23478-01.dmp]
    Debug session time: Tue Dec 26 02:55:20.251 2017 (UTC - 5:00)
    System Uptime: 0 days 0:37:43.672
    BUGCHECK_STR:  0x116
    Arguments fffffa80`063de4e0 fffff880`0440f948 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122617-24320-01.dmp]
    Debug session time: Tue Dec 26 14:35:57.382 2017 (UTC - 5:00)
    System Uptime: 0 days 5:06:08.443
    Probably caused by : atikmpag.sys ( atikmpag+f99c )
    BUGCHECK_STR:  0x116
    Arguments fffffa80`086f7010 fffff880`0478499c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122617-24679-01.dmp]
    Debug session time: Tue Dec 26 09:28:58.387 2017 (UTC - 5:00)
    System Uptime: 0 days 4:34:27.433
    BUGCHECK_STR:  0x116
    Arguments fffffa80`04c85010 fffff880`0420f99c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122617-27830-01.dmp]
    Debug session time: Tue Dec 26 03:58:16.202 2017 (UTC - 5:00)
    System Uptime: 0 days 1:02:08.263
    BUGCHECK_STR:  0x116
    Arguments fffffa80`08dc3010 fffff880`04351948 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122717-24117-01.dmp]
    Debug session time: Wed Dec 27 13:50:48.315 2017 (UTC - 5:00)
    System Uptime: 0 days 0:18:09.735
    BUGCHECK_STR:  0x116
    Arguments fffffa80`082f2010 fffff880`0436999c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122717-24975-01.dmp]
    Debug session time: Wed Dec 27 10:38:33.505 2017 (UTC - 5:00)
    System Uptime: 0 days 7:12:38.925
    BUGCHECK_STR:  0x116
    Arguments fffffa80`08882010 fffff880`0420f99c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122717-26395-01.dmp]
    Debug session time: Tue Dec 26 15:27:42.883 2017 (UTC - 5:00)
    System Uptime: 0 days 0:11:03.929
    BUGCHECK_STR:  0x116
    Arguments fffffa80`0820d010 fffff880`04a5b99c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122717-26800-01.dmp]
    Debug session time: Wed Dec 27 14:03:22.106 2017 (UTC - 5:00)
    System Uptime: 0 days 0:11:11.620
    BUGCHECK_STR:  0x116
    Arguments fffffa80`07259010 fffff880`04b0499c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3208
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122817-24757-01.dmp]
    Debug session time: Wed Dec 27 17:13:48.453 2017 (UTC - 5:00)
    System Uptime: 0 days 3:10:00.873
    BUGCHECK_STR:  0x116
    Arguments fffffa80`091f84e0 fffff880`04a2599c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122817-26083-01.dmp]
    Debug session time: Thu Dec 28 13:58:49.321 2017 (UTC - 5:00)
    System Uptime: 0 days 0:15:29.741
    BUGCHECK_STR:  0x116
    Arguments fffffa80`0537e010 fffff880`0477a99c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122817-29000-01.dmp]
    Debug session time: Wed Dec 27 17:19:57.124 2017 (UTC - 5:00)
    System Uptime: 0 days 0:05:44.544
    BUGCHECK_STR:  0x116
    Arguments fffffa80`03948010 fffff880`0434699c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122817-29608-01.dmp]
    Debug session time: Thu Dec 28 08:45:25.173 2017 (UTC - 5:00)
    System Uptime: 0 days 0:48:00.594
    BUGCHECK_STR:  0x116
    Arguments fffffa80`04e29010 fffff880`0420f99c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\122917-24757-01.dmp]
    Debug session time: Thu Dec 28 20:01:02.176 2017 (UTC - 5:00)
    System Uptime: 0 days 6:01:45.597
    BUGCHECK_STR:  0x116
    Arguments fffffa80`03dd9160 fffff880`0420f99c 00000000`00000000 00000000`00000002
    BiosVersion = V1.12
    MaxSpeed:     3200
    CurrentSpeed: 3200
    https://www.sysnative.com/
    Thank You!
    Microsoft MVP 2009-2015
Similar Threads
  1. [SOLVED] New PC BSOD MEMORY_MANAGEMENT error
    By saifsmailbox98 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 01-29-2016, 03:59 PM
  2. BSOD Error - Windows 10 x64
    By waggyman101 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 08-27-2015, 05:21 AM
  3. BSOD ntoskrnl.exe / cfs Error on CNBJ2530.DPB / dsim error 0x800f0906
    By couda in forum BSOD, Crashes, Kernel Debugging
    Last Post: 09-10-2014, 02:12 PM
  4. [SOLVED] BSOD Kernel 41 Error
    By kevinhen16 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 11-02-2013, 01:01 PM
  5. BSOD 116 Error
    By Nthan in forum BSOD, Crashes, Kernel Debugging
    Last Post: 12-13-2012, 02:49 PM
Log in
Log in
