Page 2 of 2 First 12
  1. #21
    Moderator
    BSOD Kernel Dump Analyst
    Windows Update Instructor
    softwaremaniac's Avatar
    Join Date
    Oct 2014
    Croatia
    Age
    23
    • specs System Specs
      • Motherboard:
        ASUS MAXIMUS ROG HERO X
      • CPU:
        Intel Core i7-8700K 3.7GHz
      • Memory:
        Crucial 2x8GB DDR4 2666 MHz
      • Graphics:
        Gigabyte GTX 1080 G1 Gaming 8 GB
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
        WD Caviar Black 1TB SATA III 7200rpm, WD Caviar Black 6TB SATA III 7200rpm
      • Disk Drives:
        Samsung 960 Evo 256GB NVME PCIe
      • Power Supply:
        Corsair HX 750W 80+ Platinum
      • Case:
        Fractal Design Define R6
      • Cooling:
        Noctua NH-D14
      • Display:
        Philips Brilliance BDM4065UC 4K 3840x2160
      • Operating System:
        Windows 10 Pro 1803 x64
    Re: Reinstalled Windows 10 to fix corrupted files, BSoD. Didn't fix anything.
    Was it removed from the list eventually?
    Can you try it from Safe Mode?
    If this doesn't work, I'll do something else.
    twillo says thanks for this.
    • Ad Bot
      advertising
      Beep.
  2. #22
    Moderator
    Join Date
    Oct 2014
    Croatia
    Age
    23
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
      • Cooling:
        Noctua NH-D14
      • Display:
      • Operating System:
    If that doesn't work, please follow these instructions:
    GSmartControl
    • Extract the content of the GSmartControl.zip archive and execute gsmartcontrol.exe; To extract you can right-click your mouse on the GSmartControl.zip file and select Extract.
    • Also, go in the Attributes tab and if you have any entries highlighted in red or pink, take a screenshot of the GSmartControl window and attach it in your next reply.
  3. #23
    I ended up just resetting the PC since there was nothing on it to lose anyway. It seems to have cleared up the issue as I no longer have trouble running the programs.
    Thanks
  4. #24
    Moderator
    Join Date
    Oct 2014
    Croatia
    Age
    23
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
      • Cooling:
        Noctua NH-D14
      • Display:
      • Operating System:
    Thanks for letting me know.
Similar Threads
  1. Laptop reinstalled bsod's and other problems - Windows 7 x64
    By haramo in forum BSOD, Crashes, Kernel Debugging
    Last Post: 07-24-2015, 06:49 AM
  2. Bad_Pool_Caller - BSOD Windows 8.1 led to sfc /scannow revealing corrupted files
    By sarathnair in forum BSOD, Crashes, Kernel Debugging
    Last Post: 06-25-2015, 06:33 PM
  3. Reinstalled OS on ASUS laptop but BSOD still persists. Help! - Windows 8 x64
    By Yancey in forum BSOD, Crashes, Kernel Debugging
    Last Post: 10-17-2014, 07:02 PM
  4. BSOD and SFC scannow cannot fix certain corrupted files.
    By Painz in forum BSOD, Crashes, Kernel Debugging
    Last Post: 08-23-2013, 02:52 PM
Log in
Log in
