Page 1 of 2 12 Last
  1. #1
    BSOD randomly playing games.HELP!
    Hello guys, First of all, thanks for the help I really need because I do not know what else to do. VIDEO_SCHEDULER_INTERNAL_ERROR is an error. I have exchanged my memory with a friend and the error continues. I already switched video card with it too. When he installed my video card in his computer, and the memory, he did not have that problem. Thanks a lot for the help. I have already performed a stress test with Furmark and did not present BSOD. I already tested CPU stress and did not have any problems. Memory too. Please help me solve this problem. Thank you very much.
    All drivers.BIOS, and Windows, are up to date.
    I had opened a topic previously, but they said that my copy was not original. I formatted and installed a genuine copy and the BSOD problem continues
    · OS - Windows 10
    · x64
    · What was original installed OS on system?
    · Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)?
    · Age of system (hardware) - 1 month
    · Age of OS installation - have you re-installed the OS? Yes, 4 days
    · CPU - Ryzen 1600
    · Video Card - Gigabyte GTX 1060 G1 Gaming
    · MotherBoard -
    MSI Tomahawk Arctic
    · Power Supply - CORsair 600W
    Attached Files Attached Files
    • Ad Bot
      advertising
      Beep.
  2. #2
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
    • specs System Specs
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
        12GB DDR3L SDRAM (2 DIMM)
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    Re: BSOD randomly playing games.HELP!
    Hi. . .
    The bugchecks on the 2 BSODs -
    0x3b - system service threw an exception; excp = memory access violation (0xc5)
    0x119 - video scheduler has detected a fatal violation.
    The probable cause on the first was NVIDIA video. Update your NVIDIA driver - Driver Reference Table - nvlddmkm.sys
    The second BSOD named the NT Kernel as the probable cause. It IS NOT the cause -- it's merely listed as a default.
    The process listed in the second BSOD -
    PROCESS_NAME:  DriverBooster.
    Uninstall Driver Booster.
    If you need to update drivers, use the Driver Reference Table (DRT) - https://www.sysnative.com/drivers/table/
    Go into Device Manager; expand the driver category; look-up the driver name via "driver" tab; look-up the driver name in the DRT.
    Regards. . .
    jcgriff2
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\061017-17375-01.dmp]
    Built by: 15063.0.amd64fre.rs2_release.170317-1834
    Debug session time: Sat Jun 10 16:22:19.064 2017 (UTC - 4:00)
    System Uptime: 0 days 2:16:22.727
    *** WARNING: Unable to verify timestamp for nvlddmkm.sys
    *** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
    Probably caused by : dxgmms2.sys ( dxgmms2!VidSchiProcessIsrFaultedPacket+23e )
    DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
    BUGCHECK_STR:  0x119
    PROCESS_NAME:  System
    FAILURE_BUCKET_ID:  0x119_5_DRIVER_FAULTED_SYSTEM_COMMAND_dxgmms2!VidSchiProcessIsrFaultedPacket
    Bugcheck code 00000119
    Arguments 00000000`00000005 ffffd98e`8493f000 ffffd98e`84934800 00000000`0001bdf5
    BiosVersion = H.40
    BiosReleaseDate = 05/10/2017
    SystemManufacturer = Micro-Star International Co., Ltd
    SystemProductName = MS-7A34
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\060917-58968-01.dmp]
    Debug session time: Fri Jun  9 21:12:23.855 2017 (UTC - 4:00)
    System Uptime: 0 days 0:32:35.547
    Probably caused by : ntkrnlmp.exe ( nt!SwapContext+1ec )
    BUGCHECK_STR:  0x3B
    FAILURE_BUCKET_ID:  0x3B_nt!SwapContext
    Bugcheck code 0000003B
    Arguments 00000000`c0000005 fffff800`8d00c2ac ffffde00`3d7e8d70 00000000`00000000
    BiosVersion = H.40
  3. #3
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    I thought that your user name looked familiar.
    Do you have a genuine copy of Windows installed?
    BSOD randomly
    Regards. . .
    jcgriff2
  4. #4
    Quote Originally Posted by jcgriff2 View Post
    Hi. . .
    Regards. . .
    jcgriff2
    BUGCHECK_STR:  0x119
    BiosVersion = H.40
    BUGCHECK_STR:  0x3B
    BiosVersion = H.40
    i update the nvidia driver Through the official website of nvidia.I did not use DriverBooster for this. I just used DriverBooster to update the other drivers.
    With respect to my other post, it was me that I created and I had a copy of windows that was not genuine and I just formatted and currently I have a genuine copy.
    Please help me.
  5. #5
    additional information : this is exactly what happens, but with different game and show BSOD before restart. buzzing sound while gaming
    Computer freezes with buzzing sound while gaming. - YouTube
  6. #6
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    If this system is just one month old and you bought it from a retailer -- take it back!
    There obviously is some unknown hardware problem that I doubt we'll ever be able to help you fix.
  7. #7
    New BSOD today
    it's really frustrating for me. new pc, and i cant use
    On Sun 11/06/2017 21:07:05 your computer crashed
    crash dump file: C:\Windows\Minidump\061117-30625-01.dmp
    This was probably caused by the following module: storport.sys (storport+0x1D550)
    Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF8000A78D550, 0x0, 0xFFFFFFFFFFFFFFFF)
    Error: KMODE_EXCEPTION_NOT_HANDLED
    file path: C:\Windows\system32\drivers\storport.sys
    product: Microsoft® Windows® Operating System
    company: Microsoft Corporation
    description: Microsoft Storage Port Driver
    Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
    This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
    The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
    crash dump file: C:\Windows\memory.dmp
    This was probably caused by the following module: storport.sys (storport!StorPortQuerySystemTime+0x9F0)
  8. #8
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    Both BSODs name the Microsoft driver storport.sys. This is listed as a default of sorts and definitely is not the cause.
    Driver Reference Table - storport.sys
    The actual cause is unknown hardware failure.
    Seriously - take the system back and demand a new one.
    Regards. . .
    jcgriff2
  9. #9
    I set up the computer from scratch piece by piece, I do not think it's a hardware problem. More BSOD when I'm playing.
    I already uninstalled the video driver with the DDU and reinstalled. Minidump files in attachment
    Crash dump directory: C:\Windows\Minidump
    Crash dumps are enabled on your computer.
    On Sun 18/06/2017 14:45:06 your computer crashed
    crash dump file: C:\Windows\Minidump\061817-19000-01.dmp
    This was probably caused by the following module: watchdog.sys (watchdog+0x355E)
    Bugcheck code: 0x119 (0x5, 0xFFFFC80FAE826000, 0xFFFFC80FAE82BAD0, 0x53F75)
    Error: VIDEO_SCHEDULER_INTERNAL_ERROR
    file path: C:\Windows\system32\drivers\watchdog.sys
    description: Watchdog Driver
    Bug check description: This indicates that the video scheduler has detected a fatal violation.
    This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0xD9E13)
    file path: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvlddmkm.sys
    product: NVIDIA Windows Kernel Mode Driver, Version 382.53
    company: NVIDIA Corporation
    description: NVIDIA Windows Kernel Mode Driver, Version 382.53
    A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 382.53 , NVIDIA Corporation).
    Google query: NVIDIA Corporation VIDEO_SCHEDULER_INTERNAL_ERROR
    On Sat 17/06/2017 18:05:26 your computer crashed
    crash dump file: C:\Windows\Minidump\061717-22906-01.dmp
    This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x26D67D)
    Bugcheck code: 0x119 (0x5, 0xFFFF900928BED000, 0xFFFF900928D87AD0, 0x96B2A)
    On Sat 17/06/2017 14:08:30 your computer crashed
    crash dump file: C:\Windows\Minidump\061717-22187-01.dmp
    Bugcheck code: 0x119 (0x2, 0xFFFFFFFFC000000D, 0xFFFFE181A9F4E960, 0xFFFF8009450E9820)
  10. #10
    Moderator
    BSOD Kernel Dump Analyst
    Windows Update Instructor
    softwaremaniac's Avatar
    Join Date
    Oct 2014
    Croatia
    Age
    23
      • Motherboard:
        ASUS MAXIMUS ROG HERO X
      • CPU:
        Intel Core i7-8700K 3.7GHz
      • Memory:
        Crucial 2x8GB DDR4 2666 MHz
      • Graphics:
        Gigabyte GTX 1080 G1 Gaming 8 GB
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
        WD Caviar Black 1TB SATA III 7200rpm, WD Caviar Black 6TB SATA III 7200rpm
      • Disk Drives:
        Samsung 960 Evo 256GB NVME PCIe
      • Power Supply:
        Corsair HX 750W 80+ Platinum
      • Case:
        Fractal Design Define R6
      • Cooling:
        Noctua NH-D14
      • Display:
        Philips Brilliance BDM4065UC 4K 3840x2160
      • Operating System:
        Windows 10 Pro 1803 x64
    this is again the same bugcheck code. 119.
    Kindly take your system in for repair, because I am completely with John on this one. This is a HW issue.
    Best,
    Mihael
  11. #11
    But witch hardware?
    CPU?
    I recently bought new memory and Mobo
  12. #12
    Moderator
    Join Date
    Oct 2014
    Croatia
    Age
    23
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
      • Cooling:
        Noctua NH-D14
      • Display:
      • Operating System:
    Download OCCT and run power supply test for 15 minutes to 1 h max.
    Download
    pirata292 says thanks for this.
  13. #13
    I ran the test for about 50 minutes and no BSOD was related.
    The only thing was that during the test, the screen froze for about 1 minute and the test continued. Do you want the print screen files of the tests?
  14. #14
    Moderator
    Join Date
    Oct 2014
    Croatia
    Age
    23
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
      • Cooling:
        Noctua NH-D14
      • Display:
      • Operating System:
    Yes. What were the temps like during the test, especially at the time of the freezing?
  15. #15
    The temperature was at 44 degrees. Files in attachment.
  16. #16
    Moderator
    Join Date
    Oct 2014
    Croatia
    Age
    23
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
      • Cooling:
        Noctua NH-D14
      • Display:
      • Operating System:
    Are you using HDD or SSD or both? Also, which model(s)?
  17. #17
  18. #18
    Moderator
    Join Date
    Oct 2014
    Croatia
    Age
    23
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
      • Cooling:
        Noctua NH-D14
      • Display:
      • Operating System:
    Download HD Tune and screenshot the Health Tab please.
    If that does not show any warnings or yellow marks, kindly do the Error Scan (make sure you uncheck Quick Scan).
  19. #19
    BSOD randomly playing games.HELP!-hdd-jpg
    have a yellow mark.
    maybe faulty hard drive ?
  20. #20
    Moderator
    Join Date
    Oct 2014
    Croatia
    Age
    23
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
      • Cooling:
        Noctua NH-D14
      • Display:
      • Operating System:
    Before I make any conclusions please coplete the error scan and post back when it's done.
Page 1 of 2 12 Last
Similar Threads
  1. BSOD While Playing Games
    By Reishi24 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 04-22-2015, 04:37 PM
  2. BSOD when playing games - Windows 7 x64
    By Jansson in forum BSOD, Crashes, Kernel Debugging
    Last Post: 06-30-2014, 08:55 AM
  3. [SOLVED] Atikmpag.sys BSOD while playing games
    By AustinOlig in forum BSOD, Crashes, Kernel Debugging
    Last Post: 01-07-2014, 01:50 AM
  4. My PC randomly restarts when I'm playing games
    By scotta1212 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 09-13-2013, 02:47 PM
  5. BSOD when playing games
    By ThomasG in forum BSOD, Crashes, Kernel Debugging
    Last Post: 10-27-2012, 07:31 AM
Log in
Log in
