1. #1
    Driver Power State Failure BSOD
    Hi, new to this forum so hopefully I'm doing this right.
    I've recently been having some trouble with my Lenovo Y70-50 laptop running Windows 10 Home build 14393, x64. At seemingly random intervals, my computer will freeze up for a few seconds and then my Wifi will start acting up - it will say that the current network has no internet connection, and when I go to the Wifi menu only that network is available. I have an Intel AC 7620 Wifi adapter, and when I go into device manager the adapter is greyed out as if it were disabled, and clicking enable does nothing. I only get a BSOD when I restart my computer, where it will BSOD. I am unsure whether it is crashing before the computer can completely shut down or if it is crashing as soon as the system attempts to reboot. In any case, I am able to successfully restart my computer after the BSOD screen, where everything is working normally. If I do not restart my computer, it appears as if it has normal functionality, just without a working Wifi adapter. The BSOD gives me a Driver Power State Failure error. I've already disallowed the computer from shutting down the adapter to save power. This issue has only been occurring for the last week and a half or so, and I don't remember anything that occurred in that time frame that would have significantly changed my system.
    My laptop is around 1.5-2 years old, and the OS is the same one originally installed on the laptop (I also do not own a retail copy of Windows 10, so hopefully I won't have to do a complete reinstall). I also have not replaced any of the hardware components, so they are all the same parts that came with the laptop originally. I'm running on an Intel Core i7-4720HQ @ 2.60GHz, quad core. I have an integrated Intel 4600 graphics card and an nVidia GTX 960M. I have the latest nVidia drivers and I manually installed the latest Intel driver for my integrated card and uninstalled the manufacturer driver, but the problem persists.
    I believe I have around 5 minidump files in the zip archive. The 3 from May 16 were Driver Verifier crash dumps, although I was unable to fully debug their contents. The 3 should be more or less identical since I was having trouble successfully rebooting normally, since Verifier would crash my system on startup. They appeared to point towards the CyberDrive driver as a problem so I've since uninstalled that program, although I am unable to confirm if there were any other offending drivers, as I needed to use my computer and couldn't dedicate more time to testing further drivers and the computer appeared to be functioning normally enough. The two dated May 18 are BSODs after normal use, and were the first after uninstalling CyberDrive on the 16th. I am unable to discern any real pattern to when the failure occurs - it seems to be at random, sometimes lasting an entire day without an issue and sometimes after 30 minutes after a fresh restart. I would appreciate any suggestions as to what I should do, as my attempts as a novice to analyse the dumps via Windbg have been largely unsuccessful.
    Attached Files Attached Files
    • Ad Bot
      advertising
      Beep.
  2. #2
    writhziden's Avatar
    Join Date
    May 2012
    Colorado
    • specs System Specs
      • Manufacturer:
        Sony
      • Model Number:
        VPCF232FX/B
      • Motherboard:
        Sony Corporation VAIO
      • CPU:
      • Memory:
        8.00 GB Crucial CT2KIT51264BF1339 DDR3 1333
      • Graphics:
      • Sound Card:
        Realtek High Definition Audio/nVidia High Definition Audio
      • Hard Drives:
        TOSHIBA MK5061GSY 500 GB (465 GB actual)
      • Case:
        Laptop black matte case with backlit keyboard
      • Cooling:
        Air cooling via fan and heat exchanger heatsink
      • Display:
        Laptop display
      • Operating System:
        Windows 7 Home Premium 64 Bit
    Re: Driver Power State Failure BSOD
    My prime suspects:
    dtsoftbus01.sys Thu Jun 20 01:22:51 2013 (51C2ADCB)
    Daemon Tools driver [br] Possible BSOD issues in Win7, Win8, Win8.1 and Win10 Download DAEMON Tools for free - DAEMON-Tools.cc
    http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys
    CLVirtualDrive.sys Mon Nov 11 20:31:36 2013 (5281A118)
    CyberLink Virtual Device Driver Customer Support - Updates | CyberLink
    http://www.carrona.org/drivers/driver.php?id=CLVirtualDrive.sys
    I am only a volunteer helping users on the forums. Please wait 72 hours before double posting or PMing for help. I appreciate your patience. :-}
  3. #3
    writhziden's Avatar
    Join Date
    May 2012
    Colorado
      • Manufacturer:
        Sony
      • Model Number:
        VPCF232FX/B
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Case:
      • Cooling:
      • Display:
        Laptop display
      • Operating System:
    Beyond the above, I am not inclined to help further. You have some rather disturbing software installed on your system that sends my moral compass south.
  4. #4
    I have taken care of the troublesome drivers and so far have had no issues. Regardless of your stance on this system, I truly do appreciate the help. If there are no issues for the next little while, I will mark this thread as solved.
    writhziden says thanks for this.
Similar Threads
  1. [SOLVED] BSOD Win 8.1, driver power state failure after awaking from sleep
    By concord72 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 03-12-2015, 04:53 PM
  2. [SOLVED] BSOD - DRIVER POWER STATE FAILURE (ACPI.sys)
    By Fardarkside in forum BSOD, Crashes, Kernel Debugging
    Last Post: 09-28-2013, 05:54 PM
  3. BSOD Driver Power State Failure keeps occuring on my ASUS VivoTab.
    By Gliderpilot9 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 05-01-2013, 10:23 AM
  4. [SOLVED] BSOD - DRIVER POWER STATE FAILURE
    By maharlikans in forum BSOD, Crashes, Kernel Debugging
    Last Post: 01-06-2013, 05:26 AM
  5. MS iSCSI Initiator (Driver power state failure) BSOD
    By Novice1 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 11-30-2012, 01:59 PM
Log in
Log in
