1. #1
    BSOD, Crash, and auto Reboot. Been trying for a month now, help!
    Hello,
    I've been running into issues trying to enable and keep my SLI stable on my PC. After enabling SLI, whenever I restart I'll be facing a BSOD "DRIVER_OVERRAN_STACK_BUFFER" and the only way for me to get back into Windows 10 is to access the restore point.
    After trying pretty much everythings, here's the things that are OKAY and NOT OKAY.
    OKAY
    • Running either one 1080 by itself (Benchmark, Gaming stable 24hours.)
    • Running both 1080s, but without SLI bridge (Device Manger detects them correctly.)
    • Changed to another 2 different branded 1080s in SLI (Benchmark, Gaming stabled 24hours.)
    • Running 32gb DDR4-3200 rams (No problem)
    NOT OKAY
    • Connecting SLI Bridge (PC would boot fine the 1st time, can run benchmark/games. But after rebooting the PC would run into the BSOD code above indefinitely.)
    • Tried drivers 376.60 / 376.13 / 372.19 (Tried almost every recent driver I could, but PC still wont boot after enabling SLI, running into the BSOD code above indefinitely.)
    I have scoured through this forum, and it seems like for my issue I need to post the following files for y'all to peruse through.
    • Nvidia System Information File
    • Driver Verifier dmp. file (Have it on my PC, website won't let me upload as an attachment.)
    Tried fixing it myself for 3 weeks now, and have since passed to the guys at my local pc show for 1 week, we're all stuck and can't figure out whether its a hardware or software issue. Figured I should give you guys a try, thanks so much in advance.
    Attached Files Attached Files
    • Ad Bot
      advertising
      Beep.
  2. #2
    Re: BSOD, Crash, and auto Reboot. Been trying for a month now, help!
    Just went through all my .dmp files, and found out in every single one of them nvlddmkm.sys was the cause. If I'm not mistaken this is one of Nvidia's driver eh?
  3. #3
    Join Date
    Dec 2014
    Germany
    spare info about your System,
    Win10, Build?
    Mainboard? may be an X99 Board-Typ.
    Overclocked?
    SLI-Ready Board?
    PSU has enough power to drive both? ~1KW
    your nVidia output shows
    >> Bus: PCI Express x8 Gen3 <<
    i would have expected PCIe x16 Gen3 for both Cards here.
    but a Dump would be fine anyway, external linked may be ok too.
  4. #4
    xilolee's Avatar
    Join Date
    Dec 2013
    World, Europe, Italy
    • specs System Specs
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
        Windows 10 Home/Standard x64
    Hi Guinny.
    Could you run the BSOD file collection app (click) and post the archived logs here?
      1. System Manufacturer?
      2. Laptop or Desktop?
      3. Exact model number (if laptop, check label on bottom)
      4. OS ? (Windows 10, 8.1, 8, 7, Vista)
      5. x86 (32bit) or x64 (64bit)?
      6. Service pack?
      7. What was original installed OS on system?
      8. Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)?
      9. Age of system? (hardware)
      10. Age of OS installation?
      11. Have you re-installed the OS?
      12. CPU
      13. RAM (brand, model, which slots are you using?)
      14. Video Card
      15. MotherBoard - (if NOT a laptop)
      16. Power Supply - brand & wattage (if laptop, skip this one)
      17. What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth)
      18. Are you using proxy, vpn, ipfilters or similar software?
      19. Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software)
      20. Are you currently under/overclocking? Are there overclocking software installed on your system?
    • Facultative step: Retrieve System Information, using speccy
      1. Download Speccy portable - actual version 1.29.714 (click), unzip/decompress it and put it on your desktop.
      5. (Or attach the log here, if you prefer to not publish it for some reason)
Similar Threads
  1. [SOLVED] Random crashed, no BSOD, screen/sound freezes and reboot is required -Windows 8.1 x64
    By anmihe in forum BSOD, Crashes, Kernel Debugging
    Last Post: 06-06-2015, 10:05 PM
  2. My Several Month Office Remodel
    By Anthony N in forum The Lounge
    Last Post: 05-05-2013, 07:59 PM
  3. Repeated BSOD, Windows 8 with various error messages on reboot
    By jrams2594 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 03-20-2013, 04:28 AM
  4. 9 Month-old dies after being locked in a hot car
    By jcgriff2 in forum The Lounge
    Last Post: 09-11-2012, 09:10 PM
Log in
Log in
