Page 1 of 2 12 Last
  1. #1
    BSOD when running 2 ragnarok online applications (cdd.dll)
    Hi there. I just changed my hard drive from 160GB to 500GB. After installing the OS and antivirus and some updates, I installed this game. The problem is whenever I open 2 applications at the same time, a BSOD always appears. I hope you can assist me with my problem as I have no idea whatsoever about what to do about this. Thank you.
    Attached Files Attached Files
    • Ad Bot
      advertising
      Beep.
  2. #2
    satrow's Avatar
    Join Date
    Apr 2012
    Cymru
    • specs System Specs
      • Motherboard:
        ASRock Z77E-ITX
      • CPU:
        E3-1230 V2 3.3GHz
      • Memory:
        16GB G.Skill DDR3 2400
      • Graphics:
        Asus GTX1060
      • Sound Card:
        Onboard
      • Hard Drives:
        3x250GB SSDs, 2x 2.5 1TB HDD JBOD
      • Power Supply:
        Seasonic 360W Gold
      • Case:
        BitFenix Prodigy Black
      • Cooling:
        Be Quiet Shadow Rock Topflow + 2x case fans
      • Display:
        Dell U2412M 1900x1200 x2 (sometimes x3)
      • Operating System:
        W7 x64 Pro
    Re: BSOD when running 2 ragnarok online applications (cdd.dll)
    Welcome :)
    I haven't looked at the file but many online games have an anti-cheat system to prevent the use of 2 games running simultaneously on the same PC.
  3. #3
    Thanks.
    In this game, you can do it just fine. It was working fine when I was still using my 160GB hard drive. The recent change in my hard drive is really what's getting me baffled as to why I am experiencing this now.
  4. #4
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
        12GB DDR3L SDRAM (2 DIMM)
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    Hi -
    you need to install Windows 7 SP1 - http://support.microsoft.com/sp
    Regards. . .
    jcgriff2
    BSOD SUMMARY
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\062212-15288-01.dmp]
    Built by: 7600.16385.x86fre.win7_rtm.090713-1255
    Debug session time: Fri Jun 22 03:10:10.110 2012 (GMT-4)
    System Uptime: 0 days 0:21:11.921
    DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
    BUGCHECK_STR:  0x50
    PROCESS_NAME:  csrss.exe
    FAILURE_BUCKET_ID:  0x50_cdd!CopyBits+b7
    Bugcheck code 00000050
    Arguments 81f7c3f8 00000000 94961887 00000001
    BiosVersion = F4
    BiosReleaseDate = 04/29/2009
    SystemManufacturer = Gigabyte Technology Co., Ltd.
    SystemProductName = GA-MA78GM-US2H
    ииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииииии``
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\062212-15381-01.dmp]
    Debug session time: Fri Jun 22 03:13:23.412 2012 (GMT-4)
    System Uptime: 0 days 0:02:09.223
    BUGCHECK_STR:  0x50
    PROCESS_NAME:  explorer.exe
    FAILURE_BUCKET_ID:  0x50_cdd!DrvBitBlt+aeb
    Arguments fd400000 00000000 9474b2e3 00000000
    BiosVersion = F4
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\062212-16380-01.dmp]
    Debug session time: Fri Jun 22 02:43:14.724 2012 (GMT-4)
    System Uptime: 0 days 0:03:33.550
    BugCheck 1000007E, {c0000005, 94791887, 82178304, 82177ee0}
    Probably caused by : cdd.dll ( cdd!CopyBits+b7 )
    BUGCHECK_STR:  0x7E
    FAILURE_BUCKET_ID:  0x7E_cdd!CopyBits+b7
    Bugcheck code 1000007E
    Arguments c0000005 94791887 82178304 82177ee0
    BiosVersion = F4
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\062212-16489-01.dmp]
    Debug session time: Fri Jun 22 02:38:01.020 2012 (GMT-4)
    System Uptime: 0 days 0:43:55.830
    BUGCHECK_STR:  0x50
    Arguments 81f7c3f8 00000000 94821887 00000001
    BiosVersion = F4
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\062212-16598-01.dmp]
    Debug session time: Fri Jun 22 02:48:17.579 2012 (GMT-4)
    System Uptime: 0 days 0:03:55.389
    BugCheck 1000007E, {c0000005, 94987b14, 89f802f4, 89f7fed0}
    Probably caused by : cdd.dll ( cdd!memcpy+c4 )
    BUGCHECK_STR:  0x7E
    FAILURE_BUCKET_ID:  0x7E_cdd!memcpy+c4
    Arguments c0000005 94987b14 89f802f4 89f7fed0
    BiosVersion = F4
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\062212-16707-01.dmp]
    Debug session time: Fri Jun 22 01:47:59.965 2012 (GMT-4)
    System Uptime: 0 days 0:03:52.650
    BugCheck 1000008E, {c000001d, ed33701, 8268751c, 0}
    Probably caused by : dxgkrnl.sys ( dxgkrnl!DXGCONTEXT::Present+2378 )
    BUGCHECK_STR:  0x8E
    PROCESS_NAME:  ekro.exe
    FAILURE_BUCKET_ID:  0x8E_BAD_IP_dxgkrnl!DXGCONTEXT::Present+2378
    Bugcheck code 1000008E
    Arguments c000001d 0ed33701 8268751c 00000000
    BiosVersion = F4
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\062312-19297-01.dmp]
    Built by: 7601.17803.x86fre.win7sp1_gdr.120330-1504
    Debug session time: Fri Jun 22 17:17:29.202 2012 (GMT-4)
    System Uptime: 0 days 0:04:34.028
    BUGCHECK_STR:  0x50
    Arguments 81d803f8 00000000 94a4189d 00000000
    BiosVersion = F4
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\062312-19843-01.dmp]
    Debug session time: Fri Jun 22 12:54:50.242 2012 (GMT-4)
    System Uptime: 0 days 5:57:00.068
    BugCheck A, {78ad78, 2, 1, 82f327a5}
    Probably caused by : ntkrpamp.exe ( nt!PpmPerfRecordUtility+60 )
    BUGCHECK_STR:  0xA
    PROCESS_NAME:  TrustedInstall
    FAILURE_BUCKET_ID:  0xA_nt!PpmPerfRecordUtility+60
    Bugcheck code 0000000A
    Arguments 0078ad78 00000002 00000001 82f327a5
    BiosVersion = F4
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\062312-20186-01.dmp]
    Debug session time: Fri Jun 22 17:30:48.545 2012 (GMT-4)
    System Uptime: 0 days 0:05:31.356
    BUGCHECK_STR:  0xFC
    Bugcheck code 000000FC
    Arguments 9d807d08 453fa963 9d807bc8 00000002
    BiosVersion = F4
           J. C. Griffith, Microsoft MVP (jcgriff2)
               https://mvp.support.microsoft.com/profile/Griffith
               www.sysnative.com
               www.jcgriff2.com
    https://www.sysnative.com/
    Thank You!
    Microsoft MVP 2009-2015
    Windows Insider MVP 2018 - Present
  5. #5
    Thanks for that tip. Unfortunately, a new problem arose which concerns the win32k.sys file. A BSOD of that file appears now. I hope you can assist me further on this problem. Thanks a lot for this.Documents.rar
  6. #6
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    Hi -
    You have a 2009 version ESET installed; Realtek drivers need to be updated as well -
    eamon.sys    Fri Feb 06 08:14:21 2009 (498C37AD) - ESET
    ehdrv.sys    Fri Feb 06 08:15:01 2009 (498C37D5) - ESET
    epfwwfpr.sys Fri Feb 06 08:06:19 2009 (498C35CB) - ESET
    RTKVHDA.sys  Tue Jan 20 01:10:46 2009 (49756AE6) - Realtek HD Audio
    Rt86win7.sys Thu Feb 26 04:04:22 2009 (49A65B16) - Realtek Ethernet
    http://sysnative.com/drivers/driver.php?id=RTKVHDA.sys
    http://sysnative.com/drivers/driver.php?id=Rt86win7.sys
    http://sysnative.com/drivers/driver.php?id=eamon.sys
    http://sysnative.com/drivers/driver.php?id=ehdrv.sys
    http://sysnative.com/drivers/driver.php?id=epfwwfpr.sys
    Remove ESET with the removal tool - http://kb.eset.com/esetkb/index?page=content&id=SOLN146
    Reboot upon completion.
    If you have an ESET keycode - http://www.eset.com/us/download/home/
    Otherwise, Install Microsoft Security Essentials (MSE)
    Regards. . .
    jcgriff2
    BSOD SUMMARY
    Loading Dump File [C:\Users\PalmDesert\_jcgriff2_\dbug\__Kernel__\062412-24648-01.dmp]
    Debug session time: Sat Jun 23 20:55:44.214 2012 (GMT-4)
    System Uptime: 0 days 0:04:29.024
    *** ERROR: Module load completed but symbols could not be loaded for win32k.sys
    BUGCHECK_STR:  0x50
    FAILURE_BUCKET_ID:  0x50_win32k+b6d4a
    Arguments 87ddf430 00000001 82456d4a 00000000
    BiosVersion = F4
    Thank You!
  7. #7
    Thank you. I can now play 2 clients at the same time again. Unfortunately, one problem again arose. I cannot install eset 5 nor bittorent now. Whenever I try to install those, it fails and a BSOD regarding cdd.dll appears. Thanks again for your hard work.Documents.rar
  8. #8
    The most recent attached dumps are all *7e bugchecks or *50, all pointing to cdd.dll or instances of ntoskrnl.exe. In the latest attached dump file (Debug session time: Sat Jun 23 14:37:40.110 2012 (UTC - 4:00), ESET is still installed as the following drivers are still listed and loaded as of this crash dump:
    eamon.sys    Fri Feb 06 08:14:21 2009 (498C37AD) - ESET ehdrv.sys    Fri Feb 06 08:15:01 2009 (498C37D5) - ESET epfwwfpr.sys Fri Feb 06 08:06:19 2009 (498C35CB) - ESET
    As jcgriff2 has mentioned earlier, please use the ESET removal tool to safely and correctly remove ESET. You can temporarily replace ESET with MSE (Microsoft Security Essentials) if you wish.
  9. #9
    Hello. I have completely removed my eset antivirus now but the win32k.sys BSOD is back. Here are the new files. Thank you very much for trying to help me with my problem.Documents.rar
  10. #10
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    Is the video new?
    You have AMD processor & NVIDIA video -
    Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.0GHz
    Card name: NVIDIA GeForce GT 430
    Thank You!
  11. #11
    Quote Originally Posted by jcgriff2 View Post
    Is the video new?
    I bought the video card around 7 months ago. Then, I just updated the driver a few days ago.
  12. #12
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    I'm going to have to ask a hardware expert about this.
    I know AMD & NVIDIA don't always play nice together.
    Thank You!
  13. #13
    Ok. I will wait for your response.
  14. #14
    Wrench97's Avatar
    Join Date
    Feb 2012
    S.E. Pennsylvania
    A Nvidia card on a ATI board is Ok, I would D/L Memtest+ burn it to a CD using a free program like Imgburn if you need one then boot from the CD to test the ram, let it run for at least 6 passes or until you see an error.
  15. #15
    Sorry for the really late reply. I did the memtest 3 times and the results were 3 passes, 2 passes, and 3 passes. I had to do a system restore after doing those 3 tests. What does it mean if none of my tries reached 6 passes?
  16. #16
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    Hi -
    Did you run the CD bootable memtest86+ as Wrench97 instructed?
    It is DOS-based - Windows does not load, so System Restore would not come into play at all.
    You should run memtest86+ one stick at a time & alternate the slots.
    Regards. . .
    jcgriff2
    Thank You!
  17. #17
    Hello there. Yes, I booted from the CD as instructed and that DOS-based program appeared. I used system restore after running the memtest thrice because windows could not load after and a BSOD appears which disappears fast which makes me unable to see what caused the error whenever I restart my PC. As I mentioned, I did it thrice and it had passes of 3,2,3 respectively. What should I do now?
  18. #18
    jcgriff2's Avatar
    Join Date
    Feb 2012
    New Jersey Shore
      • Manufacturer:
        HP
      • Model Number:
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
        90w
      • Case:
        Laptop
      • Display:
      • Operating System:
        Windows 8.1
    Is there a new dump file --> \windows\minidump
    If so, please zip it up & attach to your next post.
    Regards. . .
    jcgriff2
    Thank You!
  19. #19
    I redid the memtest once just now. I needed to do a system restore again by launching the fix startup as a BSOD always appears once I choose to start windows normally after the restarting the computer right after getting the error on the memtest. But this time, I was able to copy the cause of the BSOD which is as follows:
    STOP: 0x0000050 (0x8700F7AC, 0x00000000, 0x8606F452, 0x00000000)
    WimFsf.sys - Address 8606F452 base at 8696D000, DateStamp 4a6bc0a6
  20. #20
    I would like to apologize for having misunderstood the instruction given. It seems that I was using the usb installer of the memtest instead of the .iso one. I have finished doing the real memtest which I think is the correct one. I run it just once this time. The result was 2 passes and had 10 errors on the third cycle. Does this mean that I have to change my ram to a new one? I have attached the latest dump files I have after doing the memtestDocuments.rar. Thank you for your support.
Page 1 of 2 12 Last
Similar Threads
  1. BSoD daily - running Vista
    By Khymera in forum BSOD, Crashes, Kernel Debugging
    Last Post: 06-19-2013, 02:46 PM
  2. windows 7 BSOD in NETIO.sys when running uTorrent
    By omanoe in forum BSOD, Crashes, Kernel Debugging
    Last Post: 05-03-2013, 07:21 PM
  3. ntoskrnl.exe+18cb13 Win7 hal.dll+12a3b BSOD SOOOO ANNOYING
    By zekon in forum BSOD, Crashes, Kernel Debugging
    Last Post: 02-28-2013, 09:10 AM
  4. DLL errors: DSOUND.DLL error
    By Melissa in forum Windows Update
    Last Post: 01-27-2013, 08:32 PM
Log in
Log in
