1. #1
    BSOD, pls help lol
    Zippyshare.com - SysnativeFileCollectionApp.zip (sysnativefilecollection)
    Zippyshare.com - PERFMON.zip (perfmon)
    OS - Windows 7 64-bit
    x64
    What was original installed OS on system? Windows 10, however i thought the bsod would stop if i degraded to win 7
    Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? OEM
    Age of system (hardware) 4 months
    Age of OS installation - have you re-installed the OS? 15 days, yes I have.
    CPU 6700k
    Video Card gtx980 ti
    MotherBoard - (if NOT a laptop) Gigabyte GA-B150m_d3h GSM rev 1.0
    Power Supply - brand & wattage (if laptop, skip this one) seasonic snow silent 750w
    System Manufacturer Microsoft
    Exact model number (if laptop, check label on bottom)
    Laptop or Desktop? Desktop
    The bsod is A clock interrupt was not received on a secondary processor....this only happens when I'm playing intensive games.
    if anyone can help i'd appreciate it lol
    • Ad Bot
      advertising
      Beep.
  2. #2
    Join Date
    Dec 2014
    Germany
    Re: BSOD, pls help lol
    bad Idea that zipshare!
    it trys to inject and attack!
Similar Threads
  1. [SOLVED] BSOD IRQL_NOT_LESS_OR_EQUAL || BSOD SYSTEM_SERVICE_EXCEPTION - Windows 7 x64
    By gisakux in forum BSOD, Crashes, Kernel Debugging
    Last Post: 07-27-2015, 06:09 PM
  2. [SOLVED] Windows 8.1 BSOD for months. need BSOD analysis.
    By Pootis in forum BSOD, Crashes, Kernel Debugging
    Last Post: 12-21-2014, 05:10 AM
  3. [SOLVED] BSOD dump. Random BSOD when not even stressed - Windows 7
    By DaRebel in forum BSOD, Crashes, Kernel Debugging
    Last Post: 05-28-2014, 06:26 PM
  4. Random BSOD + Verifier triggers BSOD on startup
    By eyeland in forum BSOD, Crashes, Kernel Debugging
    Last Post: 06-10-2012, 08:23 AM
Log in
Log in
