Page 3 of 5 First 12345 Last
  1. #41
    xilolee's Avatar
    Join Date
    Dec 2013
    World, Europe, Italy
    • specs System Specs
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
        Windows 10 Home/Standard x64
    Re: Help with random BSOD and Freezing.
    Could you re-try both commands from an elevated command prompt?
    • Ad Bot
      advertising
      Beep.
  2. #42
    nevermind scratch that whole last part I am an Idiot sorry . Ok so i copy those commands into cmd and then what
  3. #43
    Sorry I am terribly novice at this I am reading further in deepth about how to run verifier when I figure it out I will run it and get back to you with the results
  4. #44
    Ok i changed the settings accordingly in verifier like it said then I rebooted but nothing has happened am I doing something wrong?
  5. #45
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    Verifier is like a stress test: you should leave it on for 24 hours (or more), until a bsod appears.
    If no bsods appear, verifier should be disabled/reset (and this should mean there are no problems with drivers).
  6. #46
    How do I verify that it is running? I rebooted but I see no indication that it is running.
  7. #47
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    Quote Originally Posted by xilolee View Post
    To check verifier settings, open a command prompt (it should work with a simple command prompt, but it's better if you check it with an elevated command prompt) and copy/paste these commands:
    verifier /query
    verifier /querysettings
    Output (important parts in bold - strange it uses English for the first command...):
    When verifier is active, you should see some flags enabled and different codes.
  8. #48
    ok mission success I can see that it's going now, what am I to post if I don not get a bsod?
  9. #49
    Quote Originally Posted by axe0 View Post
    Quote Originally Posted by Rogue7 View Post
    The more I read about it the more it seems to fit all the symptoms, random bsod's, freezes and application errors, granted this may just be wishful thinking on my part but my roomate has almost an identical pc only real diffrence is I think he has an extra 8 gb of ram and a gtx 960, but my point is he has a 850w PSU and his system has never had a problem my PSU is only 600w.
    You could be correct, although the power consumption specs the gtx950 shows is with i7 3.2GHz, so we do not know if the same amount of power is used with your AMD FX-9590.
    If we would assume it is and including the power consumption your AMD CPU uses per what I found on the dutch tech site Tweakers.net stating the CPU uses 220W you would come to a 570W power consumption for the GPU & CPU.
    I do not know how much power your other components use, but it is a bit tight with this assumption. A small spike could be causing problems with this assumption.
    Well I have 2 sticks of ram at 8gb a piece 1.5v a simple water cooler (can't find name brand on it) and an led strip in my desktop not sure if those matter much to the overall power consumption.
  10. #50
    Of course, per what I understand it starts with 90W consumption. The more load there is the more power is required.
    What about your motherboard, mouse and keyboard? They also use power, though a lot less, but like I mentioned a small spike is enough to use more than the 30W that is left. This is why the recommendation is to get a PSU that provides at least 25% more wattage than necessary. In your case you would be on a safer side with at least a 650W or 700W PSU if you're not planning on adding stuff that require a lot of power when under load.
    Mouse and keyboard Im not sure of the manufacturer nothing special but they light up, and when my pc freezes everything stays lit up mouse, keyboard and case leds.
  11. #51
    So no blue screen while running driver verifier, even used memtest overnight and came up with no errors.
  12. #52
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    Did you also try Hard Drive (HDD) Diagnostics?
  13. #53
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    If you don't have a friend that can lend you a 750/850W (or superior) PSU, and if you are in the USA (and if you can not use the warranty to send back your PSU to the manufacturer to get another one, but superior than it), you could be interested in this ebay auction/offer:
    ebay.it - USED Seasonic X-850 80+ GOLD (click) ---> seasonic.com - X-850 webpage (click)
    On amazon and newegg, it costs $130 new...
    EDIT: too late, it probably sold it right now...
  14. #54
    Yes HDD checked out as well at this point in time im almost sure its the PSU as well will order one with warranty like suggested and get back with results. Hopefully this works thank you so much for your help!
  15. #55
  16. #56
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    $55: EVGA 210-GQ-0750-V1 (750W) PSU 80+ gold, Semi Modular, ECO Mode, 5 Year Warranty (click)
    But after I read the negative comments, 9% of buyers were unsatisfied, I'm not sure about it...
    On the other hand, it is well tested by the other 91% of buyers.
    $80: Zalman ZM750-EBT 750W PSU 80+ gold (click)
    There's only a comment for it.
  17. #57
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    Differences between 110-BQ-0750-V1 (semimodular - 80+ bronze) and 210-GQ-0750-V2 (modular - 80+ gold):
    zalman.com - ZM750-EBT specifications (click)
  18. #58
    Ordered new psu, but encountered a new bsod today was wonderning if it might be of any help
    Attached Files Attached Files
  19. #59
    Awww man :/ I have 7 error messages exactly like this in event viewer i think due to one of my bsod's:
    A corrected hardware error has occurred.
    Reported by component: Processor Core
    Error Source: Corrected Machine Check
    Error Type: Cache Hierarchy Error
    Processor APIC ID: 0
    The details view of this entry contains further information
    Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    - <System>
    <Provider Name="Microsoft-Windows-WHEA-Logger" Guid="{C26C4F3C-3F66-4E99-8F8A-39405CFED220}" />
    <EventID>19</EventID>
    <Version>0</Version>
    <Level>3</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000000</Keywords>
    <TimeCreated SystemTime="2016-08-19T04:26:47.626101300Z" />
    <EventRecordID>1867</EventRecordID>
    <Correlation ActivityID="{E5E511D7-CD2C-4DE5-BF18-68773A2E08F7}" />
    <Execution ProcessID="1208" ThreadID="1972" />
    <Channel>System</Channel>
    <Computer>DESKTOP-LR91LPB</Computer>
    <Security UserID="S-1-5-19" />
    </System>
    - <EventData>
    <Data Name="ErrorSource">1</Data>
    <Data Name="ApicId">0</Data>
    <Data Name="MCABank">2</Data>
    <Data Name="MciStat">0xd8254000000c0176</Data>
    <Data Name="MciAddr">0x0</Data>
    <Data Name="MciMisc">0xc00a0fff00000000</Data>
    <Data Name="ErrorType">9</Data>
    <Data Name="TransactionType">1</Data>
    <Data Name="Participation">256</Data>
    <Data Name="RequestType">7</Data>
    <Data Name="MemorIO">256</Data>
    <Data Name="MemHierarchyLvl">2</Data>
    <Data Name="Timeout">256</Data>
    <Data Name="OperationType">256</Data>
    <Data Name="Channel">256</Data>
    <Data Name="Length">928</Data>
    <Data Name="RawData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ata>
    </EventData>
    </Event>
    Could this mean my CPU is also going bad?
  20. #60
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    What PSU did you buy?
Similar Threads
  1. Random freezing and DRIVER_VERIFIER_DETECTED_VIOLATION error - Windows 10 x64
    By kekemon in forum BSOD, Crashes, Kernel Debugging
    Last Post: 01-16-2016, 08:36 PM
  2. BSOD, lots of hanging and freezing - Windows 8 x64
    By dwolfe in forum BSOD, Crashes, Kernel Debugging
    Last Post: 09-10-2014, 11:32 PM
  3. [SOLVED] Crashes alternating between BSoD and straight up freezing
    By CommuneCode in forum BSOD, Crashes, Kernel Debugging
    Last Post: 05-02-2014, 10:23 PM
  4. BSOD and Freezing on Windows 7
    By saeta119 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 09-09-2013, 09:17 AM
  5. Windows 7 Ultimate 64bit random freezing
    By Dezio in forum BSOD, Crashes, Kernel Debugging
    Last Post: 07-18-2013, 11:57 AM
Log in
Log in
