G GooonE Well-known member Joined May 6, 2016 Posts 80 Jun 28, 2016 #1 Hi, I'm beginner. I don't know how to use windbg, and I want a resources to do it for beginner that explains me how to use it and how to analyze BSOD. If someone can share resources (name of books, websites, articles, anything) that would be great! Thanks.
satrow Moderator, BSOD Kernel Dump Senior Analyst Staff member Joined Apr 12, 2012 Posts 972 Location Cymru Jun 28, 2016 #2 Hiya :) I've know idea of where you're currently at in your quest to debug BSODs, have you worked through these yet? https://www.sysnative.com/forums/bs...rnel-debugging-setup-windbg-symbol-setup.html https://www.sysnative.com/forums/bs...mation/360-bsod-analysis-getting-started.html BSOD Method and Tips
G GooonE Well-known member Joined May 6, 2016 Posts 80 Jun 28, 2016 #3 satrow said: Hiya :) I've know idea of where you're currently at in your quest to debug BSODs, have you worked through these yet? https://www.sysnative.com/forums/bs...rnel-debugging-setup-windbg-symbol-setup.html https://www.sysnative.com/forums/bs...mation/360-bsod-analysis-getting-started.html BSOD Method and Tips Click to expand... Hi, I didn't. Is it for beginners? I also going to install windbg now
axe0 Administrator, BSOD Academy Instructor, Security Analyst Staff member Joined May 21, 2015 Posts 3,330 Location Holland Jul 2, 2016 #4 Many things are for beginners, some things go a bit indepth so you will need to know a few things. Go through it from time to time and keep trying, it is a good way to learn to understand what others have written and a good way in becoming better in it :smile9:
