N nebking New member Joined May 23, 2016 Posts 2 May 23, 2016 #1 A few days ago while playing a game, my computer randomly shut down. Ever since, everytime I open a game, it shuts down within 30 seconds. Need help asap please!!!
S stogazull Active member Joined May 23, 2016 Posts 37 May 24, 2016 #2 Hi, check if it is temperature problem as a first step, install something like hardware monitor and check the temperature of the hardware
N nebking New member Joined May 23, 2016 Posts 2 May 24, 2016 #3 got core temp, my min core #0 is 59c max is 72c, thats without loading a game core #1 is 53c min, max is 68c
S stogazull Active member Joined May 23, 2016 Posts 37 May 25, 2016 #4 you should check the GPU ( video card ) temp, because you say that it goes off when play so probably is GPU over heating, lunch the game and keep hardware monitor open, and check if before go down the temp is very high, any blue screen or just off ?
