1. #1
    BSOD while Gaming - DRIVER_POWER_STATE_FAILURE - BasicDisplay.sys
    i got from a friend his Zotac GTX 560 Ti AMP! graphics card. Now my pc shuts down and restarts while gaming. I found crash dumps in C:\Windows\Minidump. I looked into but couldn't find anything really useful. Can you help me? :)
    Dmp file here: https://dl.dropboxusercontent.com/u/...16-9078-01.dmp
    • Ad Bot
      advertising
      Beep.
  2. #2
    Re: BSOD while Gaming - DRIVER_POWER_STATE_FAILURE - BasicDisplay.sys
    Oh sry, didn't see the posting instruction. I will add the SysnativeFileCollectionApp.zip soon if needed
  3. #3
    Join Date
    Dec 2014
    Germany
    Moin,
    your BSOD
    DRIVER_POWER_STATE_FAILURE (9f)
    A driver has failed to complete a power IRP within a specific time.
    Arguments:
    Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
    Arg2: ffffe001a191f060, Physical Device Object of the stack
    Arg3: fffff800f81afad0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
    Arg4: ffffe001a3575630, The blocked IRP
    The failing device
    Device object (ffffe001a191f060) is for:
     Cannot read info offset from nt!ObpInfoMaskToOffset
     \Driver\BasicDisplay DriverObject ffffe0019fbf8cf0
    Current Irp 00000000 RefCount 1 Type 0000001c Flags 00003044
    Dacl ffffc1027082f581 DevExt ffffe001a191f1b0 DevObjExt ffffe001a191f588 DevNode ffffe001a1725010
    ExtensionFlags (0000000000)
    Characteristics (0x00000180)  FILE_AUTOGENERATED_DEVICE_NAME, FILE_DEVICE_SECURE_OPEN
    AttachedDevice (Upper) ffffe001a1748040 \Driver\monitor
    Device queue is not busy.
    likely your Daemontools, get rid of them, specially in Win10.
    Digging into the rest of the reconstructed Stack, a cpu is hindered to do its work, also Daemontools work.
    unsure if you need this old driver and for what reason.
    Driver Reference Table - KovaPlusFltr.sys
    fffff801`7d4a0000 fffff801`7d4a3b00 KovaPlusFltr KovaPlusFltr.sys Mon Jan 25 14:23:58 2010 (4B5D9B6E)
    not the newest one?
    regards
    Michael
Similar Threads
  1. WIN 8.1 BSOD DRIVER_POWER_STATE_FAILURE (9f)
    By GooonE in forum BSOD, Crashes, Kernel Debugging
    Last Post: 05-10-2016, 01:58 PM
  2. [SOLVED] Win 10 BSOD: Driver_Power_State_Failure
    By Junkles in forum BSOD, Crashes, Kernel Debugging
    Last Post: 01-16-2016, 01:50 AM
  3. BSOD DRIVER_POWER_STATE_FAILURE 0x0000009f
    By socratesabroad in forum BSOD, Crashes, Kernel Debugging
    Last Post: 07-02-2015, 10:30 PM
  4. [SOLVED] BSOD: DRIVER_POWER_STATE_FAILURE
    By ansky26 in forum BSOD, Crashes, Kernel Debugging
    Last Post: 02-20-2014, 07:28 PM
  5. VIDEO_TDR_FAILURE and DRIVER_POWER_STATE_FAILURE BSOD
    By deuskopo in forum BSOD, Crashes, Kernel Debugging
    Last Post: 11-04-2013, 08:26 AM
Log in
Log in
